Shop accessories for other smartphones with one cart:   Android Devices   BlackBerry   iPhone & iPad   Windows Phone
Samsung ATIV SE USB Cables
Browse USB Cables for Samsung ATIV SE
Sort by:
Narrow By:
BlackBerry 4ft Micro USB Cable for Samsung ATIV SE50%BlackBerry 4ft Micro USB Cable for Samsung ATIV SE
This OEM BlackBerry USB cable with charging capability charges through USB connection to your PC.
$9.95  $19.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (2)In StockAdd BlackBerry 4ft Micro USB Cable for Samsung ATIV SE to Cart
Ventev 3.3ft Micro-USB Charging Data Cable for Samsung ATIV SE60%Ventev 3.3ft Micro-USB Charging Data Cable for Samsung ATIV SE
The Ventev 3.3ft Micro-USB Charging Data Cable features a flat cable design, making for easy, tangle-free wrapping.
$7.95  $19.99Score 4.1/5Score 4.1/5Score 4.1/5Score 4.1/5Score 4.1/5 (21)In StockView Ventev 3.3ft Micro-USB Charging Data Cable for Samsung ATIV SE Options
Samsung 3ft Micro-USB Charging Data Cable for ATIV SE50%Samsung 3ft Micro-USB Charging Data Cable for ATIV SE
It's always a great idea to have a spare micro-USB charging data cable handy in case of an emergency or even if you just need to share one with a friend!
$9.95  $19.99Score 4/5Score 4/5Score 4/5Score 4/5Score 4/5 (4)In StockAdd Samsung 3ft Micro-USB Charging Data Cable for ATIV SE to Cart
Belkin 4ft MiXiT UP Micro-USB to USB ChargeSync Cable for Samsung ATIV SE39%Belkin 4ft MiXiT UP Micro-USB to USB ChargeSync Cable for Samsung ATIV SE
Start mixing it up when it comes to charging and syncing your mobile device with the MIXIT Up ChargeSync Cable from Belkin!
$7.95  $12.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (5)In StockView Belkin 4ft MiXiT UP Micro-USB to USB ChargeSync Cable for Samsung ATIV SE Options
SCOSCHE 3ft smartSTRIKE Charge & Sync Cable for Lightning and Micro USB Devices for Samsung ATIV SESCOSCHE 3ft smartSTRIKE Charge & Sync Cable for Lightning and Micro USB Devices for Samsung ATIV SE
The smartSTRIKE is a 2-in-1 charge and sync cable that will charge both devices at any time; without the fuss!
$19.95  $24.99'Not yet rated.'In StockAdd SCOSCHE 3ft smartSTRIKE Charge & Sync Cable for Lightning and Micro USB Devices for Samsung ATIV SE to Cart
Ventev 6ft Micro-USB Charging Data Cable for Samsung ATIV SEVentev 6ft Micro-USB Charging Data Cable for Samsung ATIV SE
Now you can charge your Micro-USB mobile device without worrying about knots and tangles! Ventev's Charging Data Cable provides 6 feet of convenient charging and syncing whenever you need it.
$14.95  $19.99Score 4.6/5Score 4.6/5Score 4.6/5Score 4.6/5Score 4.6/5 (14)In StockView Ventev 6ft Micro-USB Charging Data Cable for Samsung ATIV SE Options
Samsung Power Sharing Micro-USB to Micro-USB Cable for ATIV SESamsung Power Sharing Micro-USB to Micro-USB Cable for ATIV SE
No charger or spare battery? No problem! With this cable, you can transfer power directly from one micro USB device to another.
$16.95  $19.99Score 1/5Score 1/5Score 1/5Score 1/5Score 1/5 (1)In StockAdd Samsung Power Sharing Micro-USB to Micro-USB Cable for ATIV SE to Cart
Samsung Micro-USB 5ft Charging Data Cable for ATIV SE55%Samsung Micro-USB 5ft Charging Data Cable for ATIV SE
$8.95  $19.99Score 3.3/5Score 3.3/5Score 3.3/5Score 3.3/5Score 3.3/5 (4)In StockAdd Samsung Micro-USB 5ft Charging Data Cable for ATIV SE to Cart
Ventev 6 in. Micro USB Cable for Samsung ATIV SEVentev 6 in. Micro USB Cable for Samsung ATIV SE
Flat & tangle-resistant, Ventev 6 inch chargesync cables are engineered to support higher output chargers, delivering up to 2.1A for Micro USB devices. Perfect companion for portable battery chargers.
$9.95  $12.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd Ventev 6 in. Micro USB Cable for Samsung ATIV SE to Cart
Seidio MicroUSB Cable (0.2m) 2-Pack for Samsung ATIV SESeidio MicroUSB Cable (0.2m) 2-Pack for Samsung ATIV SE
Seidio’s Micro USB Type-B high connectivity cable is a great way to keep your Samsung ATIV SE charged and updated for use.
$8.95  $9.95Score 3/5Score 3/5Score 3/5Score 3/5Score 3/5 (2)In StockAdd Seidio MicroUSB Cable (0.2m) 2-Pack for Samsung ATIV SE to Cart
Seidio MicroUSB Cable (1.0m) 2-Pack for Samsung ATIV SESeidio MicroUSB Cable (1.0m) 2-Pack for Samsung ATIV SE
$8.95  $9.95Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (2)In StockAdd Seidio MicroUSB Cable (1.0m) 2-Pack for Samsung ATIV SE to Cart
Seidio MicroUSB Cable (2.0m) 2-Pack for Samsung ATIV SESeidio MicroUSB Cable (2.0m) 2-Pack for Samsung ATIV SE
$12.95  $14.95'Not yet rated.'In StockAdd Seidio MicroUSB Cable (2.0m) 2-Pack for Samsung ATIV SE to Cart
[Fuse] Chicken TITAN LOOP M Key Chain Micro-USB Cable for Samsung ATIV SE[Fuse] Chicken TITAN LOOP M Key Chain Micro-USB Cable for Samsung ATIV SE
Meet TITAN LOOP M - The Toughest Key Chain Cable on Earth. TITAN LOOP M extends to nearly 25cm / 9in long, but loops in half to attach to your key chain, belt loop, backpack, or Laptop bag.
$14.95  $14.95'Not yet rated.'In StockAdd [Fuse] Chicken TITAN LOOP M Key Chain Micro-USB Cable for Samsung ATIV SE to Cart
[Fuse] Chicken 3.3ft TITAN M Micro-USB Cable for Samsung ATIV SE[Fuse] Chicken 3.3ft TITAN M Micro-USB Cable for Samsung ATIV SE
The frayed cables, cords tied in knots, and the family pet chewing on our charger. TITAN solves all of that and more with it's industrial-grade cable.
$24.95  $24.95Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd [Fuse] Chicken 3.3ft TITAN M Micro-USB Cable for Samsung ATIV SE to Cart
Ventev 2-in-1 USB Cable (Micro USB and USB Type C) for Samsung ATIV SEVentev 2-in-1 USB Cable (Micro USB and USB Type C) for Samsung ATIV SE
The chargesync 2-in-1 cable includes a Micro USB and USB Type-C connector in one cable. This flat, tangle-free cable is perfect for those who own multiple devices or have the newest USB-C devices.
$19.95  $24.99Score 5/5Score 5/5Score 5/5Score 5/5Score 5/5 (1)In StockAdd Ventev 2-in-1 USB Cable (Micro USB and USB Type C) for Samsung ATIV SE to Cart
Mobi Products 3-in-1 USB Charging Cable for Samsung ATIV SEMobi Products 3-in-1 USB Charging Cable for Samsung ATIV SE
The Mobi Products 3-in-1 USB Charging Cable includes a Lightning, Micro-USB, and USB Type-C connections. Now you have the ability to charge different devices simultaneously.
$12.00  $15.00'Not yet rated.'In StockAdd Mobi Products 3-in-1 USB Charging Cable for Samsung ATIV SE to Cart
Shop by Category
Customer Care
Powered by...
Our Customers Say...
